- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
What kind of heat are you talking about?
My Panorama II in the heat began to reboot.
Leave your car in the sun, outside temperature was 32 C (89 F). When included DVR began constantly overloaded. When it cooled down, began to operate normally. Inside the car, the temperature was 50 ° C (122 F).What kind of heat are you talking about?
Original Samsung 32 GbWhat memory card are you using?
Yes, full size SD card (was supplied). This incident never happened. I think a temporary or one-time glitch.Full size SD card I take it, not a micro in an adapter?
Could be a faulty product perhaps, the temps aren't high enough for that alone to be the problem
Does everyone have an issue during playback (using Registrator Viewer in jokiin's signature) where the camera has little gaps whenever it rolls to a new file? I'm using the 15mbps firmware with a Transcend 32 GB Class 10 SDHC card. Every 2 minutes during playback (my roll freqency) there's a gap in the video - sometimes up to 3 seconds. Is this just to be expected or am I doing something wrong?
There are two options:
1. Overlap need to be set to "0"
2. Some latest RV have bugs with overlap playback and stiching. I also experienced that. Went to older version RV, worked fine.
Thanks niko. I should have mentioned, overlap is already set to 0. Do you have a suggestion as to which FW I should use?
I don't have their contact details sorry, perhaps someone else that has bought from them might know
What's actually wrong with it?
D | PowerUCC Panorama II S vs Roadview Panorama GS | II / S | 7 | |
Powerucc Panorama II S - in stock | II / S | 1 | ||
D | Amp rating of Powerucc | II / S | 9 | |
I | Powerucc PanoramaII Mount | II / S | 37 | |
Powerucc Panorama S | II / S | 263 |
