Problem with Parking Mode ?
altug
Istanbul
Turkey
Hi,
I bought Viofo A129 Duo 2 weeks ago with 3 wire acc HK3 hardwire kit and since than I am having trouble with parking mode.
A professional guy made all the connections.
Yellow to acc and red to battery.
The problem is my cam never switches to parking mode. First I thought that it was due to some firmware problem so I tried all versions starting from v1.4, 1.5..2.1 and so on. None of them solved my problem.
The cam is working like it has 2 wire kit. It switches to parking mode after 90 seconds with version 1.4 or after 5 minutes with version 1.5 whatsoever. It switches back to driving mode only when it detects motion or speed higher than 8 kmh.
IT SEEMS THE CAM USES ONLY RED WIRE !
When engine is on, I pulled the red cable. It turned off.
When engine was on, I pulled the yellow cable. Nothing happened.
I even tried to reverse the connection. Yellow to battery and red to acc. When I did that, the cam started to turn with Acc on and it turned off with Acc off so I totally lost the parking mode capability.
Now, in summary :
1- It seems that red cable is not defective. It functions properly when I connect it either Acc or Battery.
2- Acc can function with red cable but somehow it doesn't function properly with yellow cable.
3- After all yellow cable is not defective at all because when I reversed the connection (red to acc and yellow to battery) only connecting the red cable to Acc didn't turn on the camera. It turned on only after I connected the yellow to battery.
Any suggestions ?
Thanks in advance.
Did You plug power cable into GPS pad or VR body (correct method) ?
ACC wire (ignition signal for park mode) passing through the GPS pad may be damaged/excluded.
