- Sep 5, 2018
- China
- AZDOME M06P Real 4K Dash Cam
Rear view mirror dash cams are a great addition to your vehicle as they provide additional safety and also help with reversing. These cameras can also come in handy when you need proof in court after an accident or when making an insurance claim. And so it is always important to make sure that you get the best by considering the following factors when shopping for one.
Resolution
Resolution of the dash cam determines the image quality that you get and so it should always be one of the first things to consider. And the simple rule here is to always settle for the best resolutions that you can afford. However, you should never settle for anything less than 720p HD as this is the minimum resolution you require in a dash cam to be able to make out things like license plates, car models, and faces.
Obstructive Design
A good rear view mirror dash cam should not obstruct anything and it should just occupy the same space or even less as your rear view mirror occupies. But, you still have to make sure that it has a large enough screen that lets you view the video and images without straining. Going for models that are mounted high on the windscreen is a simple way to ensures that it does not cause obstruction.
Look Recording
Loop recording is one of the most important features to consider when shopping for a dash cam as it makes it more convenient. It is a simple feature that ensures that the recording does not stop when the camera runs out of memory as it will overwrite the oldest content. And this means that it will continue recording indefinitely.
Night Vision
You still need to use the dash cam when driving at night, and so you should always go for ones with night vision. Although headlights and street lights can sometimes provide enough illumination for the camera you cannot always rely on them. And so the best thing is to make sure that the dash cam has a built-in feature for recording at night.
Other Features
Dash cams will come with different features and the more the features the better the model will be, but it will also be more expensive. While some of these features are not always necessary, they add to the convenience and performance of the dash come. As you are shopping for the best rear view mirror camera you should look out for extra features such as G-sensor, motion detector and auto on/off.
Conclusion
Nowadays vehicles will come with some advanced features aimed at improving your driving experience, and they include things like built-in reverse cameras and GPS. But if you have an older model without these handy features, you can always add them later one. And one of the best places to start is by installing a rear view mirror dash cam. And with our reviews above of some of the best rear view mirror cameras and buying guide you now have an idea of what to buy. But, also make sure that you compare between different models before settling on one for your vehicle.
Resolution
Obstructive Design
Look Recording
Night Vision
Other Features
Conclusion
