- Feb 6, 2016
- New England
- United States
- Viofo, GitUp
I am unaware of any image quality differences between those two versions (not saying there isn't - but was told there was not). I would be interested to see if anyone else has noticed if the HDR is darker on the v2771. Keep in mind that unless you have 2 of the same cameras side by side running the 2 different versions, it may be hard to judge one over the other. I would think you'd need the same scenarios (what the camera is capturing), unless it is completely obvious that the video is that much darker. Also, the camera has a variable bit rate, so again, unless your comparing the same exact footage using both firmware versions, it's going to vary. Unless of coarse there is a big bit rate difference.
I will ask Dome about the side button that shuts the screen off. @Pianoman144 you said this functions correctly in v2534? Also, what is the bit rate difference you are seeing?
