EricSan
- Dec 28, 2023
- Central PA
- United States
I recently received a very kind invitation from Wendy at Vantrue to review their new Nexus 5S Dashcam. A very sincere "Thank you!" to Wendy, @Jeff_Vantrue , and the Vantrue team for entrusting me with another of their cameras for review.
My other Vantrue dashcam reviews can be found here: E360, E1 Pro, N4S, S1 Pro Max, N4 Pro S, N5S
Vantrue Power (non-dashcam) Product Reviews: T800 Compressed Air Duster, TS2 Thermal Camera for iOS/Android
Features:
- Take Photo
- Video Start
- Turn On Audio
- Turn Off Audio
- Turn On Screen
- Turn Off Screen
- Turn On WiFi
- Turn Off WiFi
- Lock The Video
- Show Front Camera
- Show Rear Camera
- Inside Video On
- Back to Homepage
I have verified that all of the voice commands work as expected.
Maximum Resolutions Are as Follows:
- Front Facing Camera: Sony Starvis 2 IMX675 WDR, 2592x1944P 30fps (bitrate and file size data are here)
- Front Cabin Camera: Sony Starvis 2 IMX662 WDR, 1920x1080P 30fps (with Automatic IR LEDs)
- Rear Cabin Camera: Sony Starvis 2 IMS662 HDR, 1920x1080P 30fps (with Automatic IR LEDs)
- Rear Facing Camera: Sony Starvis 2 IMX675 HDR, 2592x1440PP 30fps
The N5S dashcam appears to be a sibling to the N4 Pro S - both cameras are very nearly the same size, but the N5S adds a 4th camera in the rear, whereas the N4 Pro S is a 3-channel model. The increased overall data rate likely accounts for why the N5S does not have Vantrue's cool PlatePix technology. There likely isn't additional processing bandwidth for that much processing.
The 4th camera is a forward-facing rear cabin camera, that when combined with the footage from the rear-facing front cabin camera has good potential to capture more area both inside and outside of the car. This looks like an interesting camera for sure! Needless to say, I'm very eager to explore the 4-channel view that it provides. As luck would have it, I embarked on a 400-mile round trip shortly after receiving this camera, so I was able to install it prior to my trip. Details and analysis to follow...
Camera angles:
- 158 degree front facing camera
- 160 degree front cabin camera
- 160 degree rear cabin camera
- 165 degree rear facing camera
Power Consumption Data:
I posted a nice table for power consumption data in post #104
User Manual and Firmware Download Page
www.vantrue.com
There is support for 32GB-1TB micro SD cards as well as for the LTE module (each available separately)
Like other Vantrue dashcams, the Nexus N5 uses super capacitors that provide 3-4 seconds of runtime after power is removed from the camera. Using capacitors is superior to using a small rechargeable battery that will eventually be unable to receive a charge due to repeated charges and heat stress.
As with Vantrue's other cameras that I have reviewed, the packaging materials are excellent and protect the camera while in transit.
The usual foam inserts hold everything snugly inside the box:
And here is everything that is included in the box. There is now a small alcohol pad included for cleaning the inside of your window before applying the static cling sheets for mounting the camera to your window. The usual 3.3ft/1m long data cable with a USB-A connector on one end and a USB-C connector on the other end is included for transferring files to your computer. The USB-C cable for the rear camera is 20ft long, has a straight USB-C male connector on one end, and a 90 degree USB-C male connector on the opposite end.
EDIT: If you happen to have more than one Vantrue multi-channel dashcam, be sure to mark the rear video cable in some manner. Because the rear camera for the N5S has TWO video channels, there are TWO pairs of wires in the longer USB-C cable, one pair for each video channel. If you get the rear cables mixed up, you'll be missing the feed from the rear cabin-facing camera. Don't mix them up!
Features:
- 4-Channel Full Coverage - This is the primary point of departure from the N4 Pro S (3ch) cameras
- Four STARVIS 2 Sensors
- LTE Connectivity
- 10s Buffered Pre-Recording Motion Detection
- 5GHz Wi-Fi & Free App
- Smart Voice Control
- Built-in GPS
- 24/7 Parking Monitoring
- Supports up to 1TB microSD Card
- Take Photo
- Video Start
- Turn On Audio
- Turn Off Audio
- Turn On Screen
- Turn Off Screen
- Turn On WiFi
- Turn Off WiFi
- Lock The Video
- Show Front Camera
- Show Rear Camera
- Inside Video On
- Back to Homepage
Camera angles:
Vantrue N5S | Product Manuals, Firmware Upgrades, and FAQs
Explore comprehensive product manuals, firmware upgrades, and frequently asked questions (FAQs) for Vantrue N5S dash cam. Access detailed instructions, troubleshooting tips, and the latest firmware updates to enhance your experience. Find answers to common queries and optimize your use of...
www.vantrue.com
