melancholyvgs311
- Nov 6, 2014
The last video file tends to be corrupt when the battery is low on the camera. Producing a corrupt file has only happened a handful of times so far and when it does I notice the battery meter is red and empty. So, I take the camera out (cause I can with that fancy mounting base and all ) and charge it up via cable on my PC. The battery meter is then full and all is fine and dandy for a good amount of time (days). I'm assuming the corruption is because it cannot keep itself on long enough to close the file out after the car is turned off, but I don't know why the battery is getting low because it's always plugged in. I had it set to only stay on 3 seconds after the car is shut down. The camera is always plugged in to my cig lighter and the light on the plug stays lit while the car is on. This is the cig lighter plug I used to charge my phone with prior to the dash cam.
I've now set the camera to never turn off automatically, only manually, and I'll turn it off before the car is shut off. Maybe that will provide some useful info.
EDIT:
Oh, and I've already updated to the 141219 firmware.
EDIT:
