I did not even think about the next clip needing to be saved. Would be just as necessary if the clip is near the end of the record time duration. Thank you for the reply.Yes that’s already how the event save button works on the SG9663DC and SGGCX2PRO
If current clip is 0-50% the previous file is also saved.
If current clip is 50-100% the next file is also saved.
DR will be the same.
It’s either a bed memory card, firmware update needed or power supply issue. If it’s none of those sounds like some hardware fault.
Thanks for being an early adopter of Street Guardian’s first 2014/2015 product line I can hook you up with a steep discount replacement if needed. Just send me a private message if interested. Things have come a long way since GC V1
Some of the other new cameras are probably single channel models, making me wonder if SG are about to try another "new" sensor, or maybe a new housing design.
Whatever, it will be interesting to see what come out of the labs.
Going with something new, will make your V1 of the GC look like a relic, even if it have just been a few years.
Fantastic
Thanks, I really appreciate the insight! So far the GCs are serving me well enough, especially if I get the other one up and running again. They'll work at least long enough to hold out for the new releases, which I'm mostly just excited for because of Gear Acquisition Syndrome 🤣Just saying if you suddenly find yourself in a situation where you can wait no more.
Any news?I don't like to say for sure but I would think we should have a better idea of where we're at by midyear, we have some tooling changes to make to accommodate a cable change that is necessary, that will take a good 6 weeks, we can retest once that is done
A compromise would be a mini-hdmi port.I think ( assume ) the LCD on the DR will be a little larger than what you see on the current models of the conventional design, but as i understand it the main unit will still be pretty small so the LCD will not be significantly larger.
Personally i had hoped for a larger main unit and so possible also LCD too, a 5" screen i would not complain about, but i don't think thats where things are heading.
So i am probably going to need my reading glasses for the DR model too, or go the WIFI route and do settings on my larger phone.
