- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
I'm about to do the F/W update on my 2 GC's today but don't understand the need for this step. What issues will there be if the card is not formatted after acquiring a GPS signal?
A secondary question: Since the A118-C works correctly with the SG GPS antenna attached is the reverse true as well? I ask because I would rather do the F/W update in the house vs car and happen to have an unused A118-C GPS unit awaiting delivery of the camera and using that would be easier than taking one out of a vehicle and putting in back afterwards.
you may have some file sorting issues if you don't do the format, best if you have stuff you want to archive just copy that off first and start with clean cards, formatting after you have signal is just so the clock is updated and the file name convention is correct before you start using the camera
you can use the GPS from the A118 when doing the update no problem, we do use a different GPS but the data format is the same and it won't cause any problems
