I am going to dispatch v3 pre-orders next working day after receiving them.My V3 version is on pre-order with @niko , hope it arrives before Christmas as it's a present from my lady to me !
Two questions:
1) What does a dual cut IR filter do?
Two questions:
2) The lens housing is shared with the A118C2. Is the lens the same as well?
I want to buy my friend a sg9665gc 3 but they only have 1 outlet in their car.
Will it work if I buy one of those 12v outlet plugs which have 2 usb ports so I can plug an iPhone charger and the dash cam of that ?
Make sure you get a high-quality one with high enough Amp output because a lot of the budget USB cig chargers are underpowered and will stress the camera. A quality mini USB cable is also required. mono price brand is the best bang for the buck reliable USB cable.
Do you have any recommendations on power supply and USB plug ?if the power supply is suitable and the USB lead you use is decent quality (many aren't) it would be fine, alternatively you could just cut the plug off the cig lead and hard wire to a switched circuit at the fuse panel
Do you have any recommendations on a high quality USB cable apart from the Mono ?
Car Charger RAVPower 54W 4-Port USB Car Charger with Quick Charge 3.0 (4X Faster) and iSmart 2.0 https://www.amazon.com/gp/B01LCFEQM4
AmazonBasics USB 2.0 Cable - A-Male to Mini-B - 3 Feet (0.9 Meters) https://www.amazon.com/gp/B00NH13S44
AmazonBasics USB 2.0 Cable - A-Male to Mini-B - 6 Feet (1.8 Meters) https://www.amazon.com/gp/B00NH11N5A
the Anker products are generally better quality, a good quality cable is also important, Monoprice are probably the best choice for reasonably priced cables of consistent/acceptable quality, longer cables in particular need to be decent quality, a lot of the cables sold online are cheap CCA and will degrade very quickly
Not something I've researched as it's not something we really encourage, we spent a lot of time already before we got to our current power supply, the two channel will use the same type of power supply but the connector will be different
