bizarrepenguin
- Feb 5, 2019
- Canada
Amazon has the V3 on sale at 130$ against SGGCX2PRO at 200$. Is the extra 70$ worth the upgrade over the V3?
The X2PRO have better low light performance ( IMX 322 Vs IMX 291 )
Question about parking mode. I have the Celllink B battery which my recently dead dashcam is connected to to have parking mode. If I plug it into to it instead of the 12 volt plug of the car, will I still be able to use parking mode?SGGCX2PRO also supports parking mode when used with SGX2HW
It does but need this https://www.blackboxmycar.ca/collec...roducts/hardwire-splicing?variant=21421566469not sure you can, works with the Cellink Neo but from memory the Cellink B doesn't have 3 wire output
They simply connected the dashcam powercable to the unspliced output to enable parking mode with Celllink B instead of having to do it our self, kind of ready for use out of the boxnot familiar with your model but you'd want the unspliced output cable
I see. Do the V3 power cable works with the PRO aswell? If so I may have an easy solutionThe spliced cable it to suit thinkware, you'd want the unspliced version to connect to the SGX2HW to enable parking mode
I mean the 12 volt power cable, the one that comes with the camera. Sorry for the confusionthe hardwire for the SGGCX2PRO is three wire so it can switch to parking mode, that's not supported in the GC
Sweet. I will likely go with the PRO but will have to double check on something beforethe non parking mode power supply is the same on both cameras, for parking mode there is a 3 wire power supply, that does not work on the GC though
I have another question about parking mode, how does it work with the PRO? Will it save the record in case of an event?the non parking mode power supply is the same on both cameras, for parking mode there is a 3 wire power supply, that does not work on the GC though
