- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Thanks, sent the details.
going out today for you
oh really now? well that is interesting...so i can just cut the plug off an solder on to a fuse tap? i had no idea....your location would show, I was on mobile at the time though and couldn't see where you are, @Street Guardian USA has the hardwire kits in stock already, I wouldn't use a generic hardwire kit though, a lot of them are not up to scratch, if you don't want parking mode though you can hardwire using the included cig charger, the power supply is not in the cig plug so that can be removed for hardwiring purposes
Thank you =Dthat's why we make the power supply the way we do, so it can be used for hardwiring, the 5 volt converter is in the little black box that's about 18 inches from the cig plug
thanks, will report back after finishing the installation.going out today for you
I do have one dumb question: How does one know whether it's safe to remove the SD card? Does the absence of any lit LEDs mean it's okay to remove the card?
not a dumb question at all, yes once the lights are out it's off and you're safe to remove the card, you can turn it off manually by pressing and holding the power button but only when you key off and the camera is in parking mode, the power button is locked out while in normal recording mode
If you find you got the wrong ones let us know and we’ll help you out.
FPS has no bearing on power draw correct?
Also, I know there’s no WiFi app specifically for it but has anyone tried any for iOS? Would be nice for testing purposes for me....ev, cpl, no cpl, etc.
I have my hardwire kit installed now. I don’t want to drop below 12.4V to keep the battery from deep cycling and can confirm at 1fps/12 hour I’m getting at least 4 hours without voltage cut. Going to play around with it more, interested too see how much time I can get at 12.4V cut.
Awesome product
Oh, you have to set both the FPS and the shutdown delay to enable Parking Mode?
Richard
once it's connected with the 3 wire supply it's enabled already
The problem is the alwaysd-on does not work.
