Damn Dirty Ape
what do you mean by this exactly?
When I turn the ignition off the parking mode does not begin.
Does it keep recording or power down completely ?
it will do that if permanent power is cut, suggest checking the circuit you have used for the yellow wire it may be timed or ECU controlledIt just turns off/stops recording.. No lights, just a power-off.
Does it make sense to leave parking mode on with my current conditions?
Work Monday-Saturday, at work at 6:45am and leave at 3:30pm
Quality: High
Parking Monitor: 5FPS
Shutdown timer: 10 minutes
Auto Restart: 1 minute
Voltage cutoff at 12.4V
Thanks for any advice - I love the camera and it works perfectly but I'm ignorant about dash cams
Have you got a manual online for the HW kit?
Any figures for the power saving (if any) in the parking mode.
I assume the space reduction is just governed by the frame rate - eg 1fps uses 1/30th of 30fps?
Also, can I add my name to the requests for other options on the parking mode timer. No time limit (ie keep recording until low voltage) would be REALLY good.
other options will come, we need to make sure everything is working correctly before enabling other settings
Installed the HWKit and set it for 5FPS and 1 hour cutoff and 12.2V yesterday. I locked the car at 8pm last night and expected to see no activity after 9pm on the SD card but when I checked this morning I see activity randomly all night.
Any idea what is causing it?
