is this HW kit a necessity for parking mode? I plan to have a Cellink Neo battery connected via cig lighter plug and have the dash cams connected directly to the Neo.
what vehicle and which circuits did you tap for permanent and accessory power?
there's a bug in this process, we're looking at it now and will put out a fix as soon as we can, thanks for the detailed info, it's helpful
1.31 is the latest beta
Call it the quest for perfection.
if you want to send any screenshots highlighting areas that can be improved always happy to look at them and see what we can do
I will the next time I have something to show you. I format the card every time I pull it from the camera, and I don't feel like doing a data-recovery job.
Any other known issues aside from setting parking mode to 5fps? After switching from 5fps back to 2fps, my unit is no longer staying on for the 12 hour timeout option I have set. I hear the two beeps when turning the car off, but it seems it only records one 3 minute segment then turns off.
what voltage setting are you using?
one three minute segment of timelapse could be an hours worth of video, did you check the file time?
When will the hardwire kit be available on other outlets, such as Amazon?
