- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Thanks for the update, anything unusual please let me know so we can have a closer look
I decided to test something last night. I had the auto shutdown set to 5 minutes. I turned my car on so the camera will start up then turned it off. The camera went in parking mode and I held the power button down till it turned off. Today I went to check on the camera and it seems to have remained off. I am wondering if its a bug with the 12 hours. I have it set to 24 hours and powered off the camera with the power button. I will see if it turns back on again.Thanks for the update, anything unusual please let me know so we can have a closer look
Also as a side note, the power button and menu button are starting to stick again. It's not as bad as what happened with the other camera but just thought I should let you know. I'm almost sure it is due to the heat. The other buttons are however fine.
ok thanks for the update
So tried the 24 hours and the camera did turn on. However, I noticed when it does power on itself it does not think the hardwire cable is plugged in. I would have to turn on and off the car for it to detect it again.
Of course [emoji41]thanks, we are still working on tracing a bug that is affecting some people so if you do see any unusual behavior please let me know
Installed my HW kit last night. Just checked today's footage and it seems to be switching perfectly between driving and parking mode every time.
The parking footage looks great, both front and rear. So far no problems for me.
My settings are 5fps, 6 hours, 12v.
Last night I switched the camera off whilst parked on my driveway and it didn't turn on by itself. The car wouldn't have been standing parked up for that long today, so can't verify whether it would have switched off after 6 hours and then magically back on sometime after that.
@jokiin Is it me that has only had this issue or other people too?
I'm not sure what affect the latest firmware has, but I'm thinking of reverting back to the previous version as that version wouldn't have the camera activate when I manually turned it off.
what version were you running previously?
what size memory card are you using?
I was running v1.32 and I'm using a Samsung 128gb memory card that came with the camera
that's the current beta, I meant what version were you running previously?
Ok thanks, you can try 1.31 also, if you see a problem in one version that's not in the other it might help us to identify the cause
Where can I download v1.31? The release notes in 1.32 don't have a link
