winter4w
- Jun 12, 2014
- G1WH
can you check fuse 14 for the permanent feed, the problem you have could be due to the permanent power going off and on or the ACC turning back on, the symptoms are more like a permanent power feed issue though
Okay just tried it and seems like it is always on. I have it recording in parking mode right now so I will see if it goes back into normal mode. Also, I am guessing it does not matter how I plug it in the fuse box? Since the other one is plugged in the fuse next to it I had to rotate it facing up instead of down.
The reason I did switch the other fuse is that it was attached to the SRS airbag system circuit so was unsure if that could cause any problems or if it could cause a safety issue.
