gps doesn't work. There is no any lights on gps when pluged in to the working camera ( Orange Or Blue)... No position and speed on record. Try to Drive 50km witch attached gps. Nothing happens. Dead unit?whats your problems?
hello, yes you can connect with the computer with USB then playback very fluencyly. you can go to our website www.shadow-tec.com to see the video.Is it possible, during playback on the computer, to have continuous stream without the breaks?
Please try this FW, this is the latest FW I got from Shadow today, don't mind about the FW version.gps doesn't work. There is no any lights on gps when pluged in to the working camera ( Orange Or Blue)... No position and speed on record. Try to Drive 50km witch attached gps. Nothing happens. Dead unit?
try this FW
QUOTE]
Thanks for the Shadow_gt680w_V2.6_FW.zip
Could you share latest version for "Full BLACK GT680W" V2.8?
I put it on full black gt680W and it is work fine. With 2.6g saves files on sd card in diffrent way than with 2.7g and they have diffrent menu...Thanks for the Shadow_gt680w_V2.6_FW.zip , But this version seem not for "FULL BLACK GT680W".
Hi guys. I have a problem with my GT680W, it lost seconds between saved movies, even up to 8 seconds.
I've put the 2.7 firmware, but it still loses a few seconds.
Any idea what firmware should I use or/and settings?
I grabbed the latest firmware from Foxoffer's blog page: https://dl.dropboxusercontent.com/u/22493212/firmware/gt680w/Shadow_GT680W_full_black_v2.7G_FW.zip
The file that extracts from there is called "FW96550A.bin". Copied it to my memory card and powered on my "All Black" model GT680W. It just turns on and firmware remains 2.6. What am I doing wrong?
It happened to me once with different product. It's the tool you used for decompressing this ZIP file. You get different results if decompressing with StuffIt and by doing it using Archive Utility. For some reason something gets lost in decompression process. Since then, I always use my PC for stuff like this. Most likely developers used PC tools when they packed it in the first place, so it's always better to play on a safe side... especially with firmware update process. Any compressor/de-compressor I use on Windows, being that WinZIP, WinRAR, 7zip, you name it... it always gives me good results. Not the same story unfortunately with Macs.Odd. It was my Mac translating the files I guess. Doing it from my windows computer I was able to get 2.7 on there. Doesn't seem any different though
Any idea what firmware should I use or/and settings...
