Ah I wouldn't worry too much about that - as long as you're getting the details on the road I wouldn't lose too much sleep over that.
The Mobius goes up to 18Mbps but it's not a huge difference in all fairness - I've run one of the cams here up to 50Mbps and again it looks nicer but you lose out on space used so it's a trade off really.
Good to know
I bought 32 GB card and tested - 2h 50min takes 18.50 GB so it is alot of space to be used
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
So far videos are good but always can be better.
I have other "problem".
As far I understand "lock" button to save videos of current events works this way - it will be saved whole 5 mins, so if you press panic button at 2 minutes since it's started recording it will record up to 5 minutes, then saves it. If you pressed save button at 4:58 minute, it will go on up to 5 minutes then saves.
Let's say there is event and video started to recording just in a moment I see it. It will record since then up to 5 minutes but previous movie will be lost, and in this previous movie are important scenes.
Is there way to save one way back movie together with current one? You know this one and 5 minutes earlier (older).
Panic button should save last 2-3 videos also.
Other question - are movies being saved in time or being kept in some kind of buffer and after 5 minutes then saved? What if there is sudden lost of power - file can be broken or not saved at all? If broken there are apps who can recover them (KMPlayer, Potplayer). If not saved at all, then it is a issue.
