Lunar
- Sep 26, 2013
- Herefordshire
- United Kingdom
- 3x Mini 0801 / Mio-368WDR+AGF
Memory.
Im not that well up on it tbh.TF,SD,SDHC - whats the difference?
Able to wrire the speed - lets say a camera (any cam really not just the 0801) has a "bit rate" of 9mb/s - then is it true to say that the memory card MUST have a minimum write speed of 9mb/s (9 million bits? per second)?
So if a camera is recording at 9mb/s - then would a "class 4" be fast enough - ever?
Its all velly confusicus.
Of course it is, in theory anyway. A class 4 card is supposedly rated to write 4MB a second, a camera that writes its video files at a bitrate of 17000kbps approx will be writing 2.1 MB per second, so one may think that if the card can write 4MBps we should be able to write our 2.1MBps quite easily ? Well while its not looping, I'm sure it's plenty fast enough.
However, when it starts to loop, and starts to delete older files, in order to record continually, The time taken to delete files continually has a massive impact on the write speeds... What this means is that some class4 cards are now not fast enough, and write errors may appear.
The class 4 cards I have tried all write around 5MBps and appear to work fine, but I have 1 Class 4 card which only writes around 3.5MBps, so I never use that one. Good quality Class 4 cards do work okay, poor or mediocre class4 cards don't.
As stated in the FAQ, users are advised to buy class 6 cards just to give that extra write speed headroom. If your current class 4 cards work when looping then that's great, but if buying new cards then class 6 is the wise option.
