or is it telling you that encoding video is ok but encoding audio and video is a struggle, is it tripping up in the write process, or earlier than that?
just been thinking about it and I'm wondering if variable bit rate encoding is part of their problem
This sounds possible, maybe tomorrow I'll run some tests to find out the actual difference in bitrate between audio + no audio, and video full hd + video 720p.
If the difference between the latter two is bigger, than what you sare suggesting sounds likely.
What's strange though is that after the camera is turned on and produces the errors, I can manually start it recording again and there will be no errors.
Therefore it might be a combination of what you suggested + the initial powering up stage (for some unknown reason!)
Hopefully the camera doesn't error overnight/in the morning when it fills up and I have to retract my last few essays
![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
