- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
Looks like it fits fine, I've installed loads of these already.
Baseplate for both the camera and the cable cover were both on, even the larger Baseplate for vertical windows still doesn't allow enough space.
But that's the problem, just with the camera alone the cables are bent against the glass so there's no room between the glass and the cables for the base of the cable cover.
Okay no worries, thanks.
I am going to do a bit of shaving with a dremel though because I'm going to also use a different usb cable plugged into a battery pack in the glove box... Plus I'm going to shorten the cover so I can put the camera further up the windscreen towards the roof.
Thanks for the lightning fast replies Pier28 and Jokiin
Nice tip, thanksIf you're really concerned another option would be to use an additional piece of 3M tape to provide additional clearance - one is included in the package.
A third option would be to remove the 3M tape from the attaching plate and replace it with industrial strength Velcro. It's much thicker and would provide more than enough clearance to satisfy your concerns.
I've use this stuff and can attest that it's adhesive qualities are nearly the same, if not equal to, the 3M stuff. I have a box sitting around all the time and it really works well for a number of things.
http://www.homedepot.com/p/VELCRO-Brand-4-ft-x-2-in-Industrial-Strength-Tape-90593/202261931
https://www.amazon.com/gp/B000068O48...the gps plug is the one that gets in the way a bit.....
....Only thing is the gps cable is two inches too short to get it to the base of my windscreen. That's no biggie though because I just stuck it on the dealer service reminder sticker on the top right of my windscreen.
or
https://www.amazon.com/gp/B004LYGGO0
...might do the trick for you.
keep in mind the GPS logo is the antenna side, also always best to run any cables to the passenger side for safety reasons
it's possible to use a 3.5mm stereo male to female extension cable if you want to extend the cable, you can extend up to about a metre without any issue
I think most people that use the cable cover don't plan on removing the camera from the mount very often if at all.
or
