- May 1, 2013
- Dublin
- Ireland
OK I missed the yellow duck, so about the standard SG9665GC I just received, but didn't use yet .
First (in belgian alphabetical order) the supplied micro-SD/USB reader doesn't work; it is recognized and installs in Windows XP but when I try to access it it says please insert a disk in drive (something), reported as CompactFlash.
Anyway the microSD card reads OK in a standard SD to micro adapter.
Very important, my NLE editing software has no problem with the movie files.
But Registrator viewer complains that it can't play the movies, missing a codec, while VLC and my NLE don't find a problem with this...
Also, I set the cam not to display the logo, but the movies are still showing StreetGuardian in the video.
I could cut it out, since its usually on the road, but in case of low-lying cliffs it could be a problem.
I would like to have a clean video, no date, time, anything...
There's also a setting I don't understand, it's the auto power-off, I get about the screen saver (display off) but I would think a capacitor-driven cam would not allow for a 5-minutes shutdown?
I just tested again the 64Gb MicroSD you received with same memory cards reader in my PC and it was reading from all USB-s I have on my PC. Could you please check lower than 64Gb mircosd cards ( 32, 16gb etc ) if you have. Maybe your USB needs update ? Anyway, let me know, if it does not work, I will send you a new one.
It is strange about Logo stamp not switching off. It works on mine. I will double check again.
Auto power-off, it should mean if you have dashcam constantly powered and recording is "paused", no buttons touched, then it will turns off after selected time.
About playback, please check if you have latest codecs.
