You need a battery discharge prevention decive.what do I need to purchase in addition if I want hard-wired parking mode functions?
Unfort dont have. Basically its similar to Panorama S, just with remote lens.Does this not have a low voltage cut off function in built like the X2?
Oh. I was under the impression it was an X2 but with the remote lens. It would explain why the graphics are completely different on the screenUnfort dont have. Basically its similar to Panorama S, just with remote lens.
Overall it can be used for so called parking in two ways when you have separately purchased battery discharge prevention device:Oh. I was under the impression it was an X2 but with the remote lens. It would explain why the graphics are completely different on the screen
Sounds great, you would have your own dual channel system with both....
...Pre-sales aren't ready yet though for the GC
1. when parked, manually select in the menu from from normal to motion detection rec.
2. drive always with motion det ON. Then no need all time switch from motion to normal and back.
U can use Pano G power lead for X1.Is the X1 power setup the same as the Panorama G? including the "35135 Nokia tip "I have just installed and hardwired the Panorama G in the front and thinking swapping to the back with the X1 in the front using the existing hardwire set up if its possible.
Yes but mic is on the main unit not camera.does this thing record sound?
