I am afraid not so soon. Maybe in few years ?When will something like this be available? Looking for all around protection4 cams and one unit
depending on where you like your horizon in the frame, you may have a bit of the tinted/dotted area in the camera's upper view. I like my frame with 55% hood/road and 45% sky. i eventually ended up lowering my camera mount to avoid the dotted area in my frame. it shows more of my camera from the exterior but you still have to intently look for it.
Hi @niko! I know the screen does not rotate 180 degrees but is it the main unit light enough to be mounted with velcro or 3M double sided tape on the headliner? Thank you!
Thanks for suggestions. I was thinking to 180 degree rotate the main unit to have the flat surface facing the headliner since I can live with the upside-down screen. And to mount it before the sunglasses holder but if you say in not light enough to be mounted with velcro or 3M double sided tape, I have to forget this mounting location since I will not use screws. Too bad the main unit is so big to accommodate a radar detector that is not even included in it. So I go back to search mounting places and hopefully I will find the right one for my car.
Thanks for the input niko I will do that once I have the cam.
Regarding the screen display, I also think the rotation function would be very helpful. Since the x1 is a street Guardian product could that feature not be added? Or is this out of the domain of firmware support?
I think @jokiin can answer regarding Street Guardian firmware upgrade plans.
