Will format as you suggested after it fills up again and fails to overwrite.Firmware 1.11 should be released this month to fix a compatibility issue with Dashcam Viewer.
@leggy
Card Full errors generally mean the card is corrupted in some way. I'd use SD Formatter and select the "overwrite" option to reset the card back to factory defaults.
If no error message put it card back in and Format in-camrea after that. (and re-test)![]()
SD Memory Card Formatter for Windows/Mac - SD Association
Watch our video on how to use the SD Memory Card Formatter SD Memory Card Formatter 5.0.4 for Windows, 5.0.3 for Mac (SD/SDHC/SDXC/SDUC) The SD Memory Card Formatter formats SD Memory Card, SDHC Memory Card, SDXC Memory Card and SDUC Memory Card (respectively SD/SDHC/SDXC/SDUC Cards) complying...www.sdcard.org
Is Dashcam viewer compatibility issue the only issue being addressed in the new firmware release or there are other enhancement as well?
