MOD-07 for 1440P resolution = 27.1Mbps // 1080P = 20MbpsMine now flashed to MOD 7 etc.
Will be trying it this week in hopefully daylight and night.
BTW, do you have a mod for the WR1?
Maximum Bit Rate is 12Mbps, can boost to 15,18,20 but testing needed for stability.
BC, think I've found a bug in Mod 7 (Stable).
If you select the resolution as 1440P30, then edit the menu, you get 1440P30.
If you select the resolution as 1440P30, then go through all the other menu items setting them to want you want, then exit at the end of the menu, the camera reverts to 1080P30 on screen, and when you re-enter the menu, the resolution menu confirms the camera is at 1080P30, even though you previously set 1440P30.
I've seen it at least 4 times with MOD-07 on A119 pro, reported to @Hobbyist once but had to re-do the video.If you select the resolution as 1440P30, then go through all the other menu items setting them to want you want, then exit at the end of the menu, the camera reverts to 1080P30 on screen, and when you re-enter the menu, the resolution menu confirms the camera is at 1080P30, even though you previously set 1440P30.
good catch, Always report BUGs to me,BC, think I've found a bug in Mod 7 (Stable).
Guaranteed VIOFO will copy then slightly modify many if not all of my adjustments and MODs into next Firmware Release, they'd be crazy not to, we've done 1 years worth of IQ testing in 22 days.Wait a minute. Will the official firmware do some of your tweaks to get a better video image? @BCHobbyist
I believe you call that video editing time shift effect to speed up the traffic light or Artistic License or Tardis MOD-7eeeeeeeeWow something odd going on there.
What I'm seeing appears at 1st to be too short a shutter duration, characterised by moving objects jumping down the road, but could more likely be frame drops in this instance, especially as the objects in question, the cars next to yours aren't moving quickly. Secondly, there then appears to be some kind of time slip issue. Although I understand video quite well, I'm not familiar enough with key frame information to understand the cause here. However, there's obviously some kind of frame / time issue and I'm inclined to think, given the starting scenario, that frames are being dropped so the duration is becoming compressed as a result. Question here whether maybe the data rate is overflowing the buffer? Maybe some kind of bug that's allowing higher than 27mps video? Other alternative that springs to mind is if the bottleneck is at the SD card, maybe it's on it's way out or of insufficient speed to allow a 27mbs write.
Excellent BUG report, complete with pictures and sound! exactly what we need for Beta testing.I just flashed my A119 Pro with the FWA119P_MOD-7c_v1.31+27Mbps+Sharp34+Edge178+DICE, setting all the fundamental menu settings,
when i double click the "menu bottom" it hangs..
https://www.dropbox.com/s/dwfsiyh52ajsxas/V_20180824_205133.mp4?dl=0
re-flashed to MOD-7 and back to normal again !
