gabilondo77
- Jun 29, 2019
- Torrevieja
- Spain
- Viofo A129 Duo,Viofo A129 Pro Duo 4K
Yup,maybe is not missing,maybe is just stopping for some miliseconds..
Open it with https://sourceforge.net/projects/vdfiltermod/?source=directoryI see that there are jumps, in which program you can see the video frame drop?
Now I clearly see the rear camera doubles frames,2 frames same image.Every 92-93 frames does that..Open it with https://sourceforge.net/projects/vdfiltermod/?source=directory
and use right/left arrow buttons to navigate between frames.
suggest repeating video test with WDR=Off and 64 GB memory card just to confirm its not the card, try to keep dashcam cool during test with air-con.Hello everyone.I've bought and installed a viofo A129 Duo camera 2 weeks ago.Everything was fine the first days with the front camera installed only,but as soon I have installed the back camera I get some frame skipping problems.The problem occur only on the back camera,every 10-15 seconds.The front camera skips too in very rare ocasions and I don't consider that a problem.I use a brand new 128GB Samsung Evo Plus U3 class10 SdCard.I have installed the modded firmware 5Wi hoping that the problem was the low bitrate of stock firmware in dual camera mode,but I have the same problem with the modded firmare too.I have made factory reset and format SdCard 3 times.I used the default settings after factory reset,and WIFI is always off,no parking mode enabled.Have somebody else experiencing this problem with Viofo A129,is this normal for this model or I have a faulty unit?
Now I see a problem, what can it be?Open it with https://sourceforge.net/projects/vdfiltermod/?source=directory
WDR is Off,camera is cool just getting out of garrage and AC is always on.I have the same problem with my two cards,samsung evo plus and viofo.Both cards are 128GB and are ok,tested.suggest repeating video test with WDR=Off and 64 GB memory card just to confirm its not the card, try to keep dashcam cool during test with air-con.
Wide Dynamic Range combines frames to brighten or darken image, its worse at night, this is a good reason to never use WDR.
Need to turn in support, what will they say?samsung evo plus and viofo.Both cards are 128GB and are ok,tested.
Tomorrow I'm going on vacation,3000km far away for 3 weeks,anyway the Amazon seller will say to send it and I will not get through the pain of desmountig/mounting again all this s...it,I will have to live with it I'm afraid....Need to turn in support, what will they say?
did you find similar double frames in recordings from any of your Viofo dashcams?Need to turn in support, what will they say?
good troubleshooting setup, you may have discovered a new hardware or firmware BUG.WDR is Off,camera is cool just getting out of garrage and AC is always on.I have the same problem with my two cards,samsung evo plus and viofo.Both cards are 128GB and are ok,tested.
No, I did not notice the problem. Would like to hear a Viofo representative on this.did you find similar double frames in recordings from any of your Viofo dashcams?
The cable doesn't make contact with another cables only in the hatch door before connection with camera,I passed the cable through A pillar and the bottom side of the doors behind that rubber protections.No extra length cable left for me.I don't think is firmware related because I had the same problem with official v1.5.good troubleshooting setup, you may have discovered a new hardware or firmware BUG.
wondering about the rear camera cabling, where does the long 6m cable route through vehicle?
does cable run across or parallel to any vehicle energized cables?
how was extra A129 rear cable length secured . . . in loops?
gotta bad feeling same issue is present in other models or related to extra long cables.
Just installed early this morning my A129 Duo. When recording front and rear I also see the hiccups when certain frames are duplicates.
If needed I can provide some samples. The FW version is the official ver1.8
