Durga Bali
Hi All,
I recently a month back bought the Viofo A129 Plus duo cam and setup in my car. First few days I saw issues of failing to record when I used Kexin and Sandisc Ultra cards. Reached to customer support and they suggested me to try with Samsung Pro Endurance or Viofo sd cards. So, I got the Samsung Pro Endurance and it looked like working fine for few days but recently failed again to record.
And I noticed one thing that after every trip I remove the sd card to review the footage in my pc and insert it before I go for next trip. This would be usually end of the day and next day or after some days as I don't commute daily. So, few times I forget to insert the sd card and start the car which starts the dash cam also with empty card. Then I realize that there is no card and insert it in the cam while it is still on. The cam restarts and looks like it started recording as I can see both the red buttons for recording and mic are on. It is here most of the times failing to record. In our trip when we stop somewhere and switch off the car and again start it and continue, the cam starts recording without fail. Only the first part where I insert the card when the cam is on till the car is switched off and started again the footage is missing. So, the question is am I missing something here? When I forgot to insert the card and switched on the cam, do I need to switch off car and insert the card and start again? When I insert the card before starting the car and the cam is off it looks like working fine.
