A139 Pro - Power Consumption Test Results
The A139 Pro is a power-hungry dash camera. I recently spent good portion of a day testing the A139 Pro in its various modes of operation (some 2-channel configurations and some 3-channel configurations). Parking mode power consumption is similar to the power consumption during normal recording modes. Based on my test results, the A139 Pro 3-channel may only last 8 to 9 hours with the 6000 mAh / 76.8 Wh dash camera battery packs on the market. The higher capacity BlackboxMyCar PowerCell 8 7500 mAh / 96 Wh dash camera battery pack should be able to power the A139 Pro 3-channel for 10 to 11 hours. If you intend on using the A139 Pro 3-channel for long parking mode sessions, you may need to have the base dash camera battery pack plus a second or third expansion battery pack to provide power for your parking needs.
I do not have the previous generation A139 3-channel dash camera, so I cannot gather power consumption data for the A139 3-channel to compare it with the A139 Pro 3-channel power consumption. In my opinion, powering the A139 Pro 3-channel configuration with the HK3-C hardwire kit using fuse taps to source power from your vehicle's fuse box would not be recommended if you're intending on getting a decent amount of parking mode recording time.
* Updated 11-05-2022 20:19 GMT-7: Retested with v1.0_1105 firmware & tested ALL camera combinations *
* Updated 11-16-2022 10:55 GMT-8: Added a note that the "Infrared LED" setting was "On" while testing with the interior infrared camera *
3-Channel Power Consumption
View attachment 62535 View attachment 62290
2-Channel (Front + Interior) Power Consumption
View attachment 62534 View attachment 62292
2-Channel (Front + Rear) Power Consumption
View attachment 62293View attachment 62294
1-Channel (Front) Power Consumption
View attachment 62298 View attachment 62299
You may notice that I added two columns to my power consumption spreadsheet showing the Max and Avg Watt values converted to 5-volt amp values. I noticed that the Watt values were quite high for some of the normal mode operations (Wi-Fi on with Live View active). The existing versions of the HK3-C and HK4 hardwire kits have a max power output rating of 5-volts / 2 Amps. The A139 Pro in a 3-channel configuration has power demands (calculated from Watt values) exceeding the 5V/2A max of the HK3-C and HK4 hardwire kits.
At no time during my testing did I observe any odd/wrong behavior that might be attributed to a power starvation situation. I raised my concerns with VIOFO. I was told an updated HK3-C will be released in the near future that addresses this concern. The 12-volt cigarette/power port adapter has a max power output rating of 5V/3A, so it should be able to supply the proper amount of power to the A139 Pro in all modes of operation.
A139 Pro - Case Temps
The A139 Pro's front camera case can get a bit warm while the front camera is configured to record 4K 2160P 24fps or 4K 1600P 30fps video. The outdoor temperatures in my location have tapered off a bit over the past several weeks. Most of my testing was with outside temps in the 70F/21.1C to 80F/26.6C range. During today's test trip, outside temps were in the mid 50F/10C range.
Today, the upper portion of the A139 Pro front camera case had temps in 155F/68.3C range. The area around the buttons was a bit warm to the touch with temps in the 115F/46.1C range.
