markus
- May 18, 2021
- Toronto, Ontario
- Canada
- VIOFO A229 Pro 2ch
Hello. I just installed my 2CH A229 Pro today. Everything seems to work fine, but I wanted to upgrade to the latest firmware. The Viofo support site shows Version: V1.0_230928 for both front and rear cameras. Where are you finding the newer versions?
So where do you go to download this latest version? Viofo's website still has September versions as the latest. Also, what format to use on the SD card, exfat or fat32, or either?Here are the latest firmwares for the front and rear cameras of the A229 Pro.
Front V1.1_231208
Rear V1.0_231207
FAT32Also, what format to use on the SD card, exfat or fat32, or either?
I have the recommended 256 GB Viofo card. Also I formatted the card in camera a couple of days ago, and it changed it from FAT32 to EXFAT!Rear camera video rotation issue
This bug is fixed in the latest version. https://drive.google.com/drive/folders/1M0MJ7kOMNJxpDY9vUi04gJ-jDbdRAuwz?usp=sharing The FWA229P is for the A229 Pro front cam, and the FWA229S is for the A229 Plus front. The EthcamTxFW.bin is for the rear cam.dashcamtalk.com
FAT32
Take a memory card up to 32 GB and you will be happy.
There is a video here on how to flash it.I have the recommended 256 GB Viofo card. Also I formatted the card in camera a couple of days ago, and it changed it from FAT32 to EXFAT!
So I formatted my SD card in the camera and it set it to exFat, how can I easily reformat it back to Fat32 so I can run the firmware upgrade please.
Not to worry I downloaded Disk Genius free edition and easily got it back to Fat32 and upgraded the firmware.
Before updating, please format the card to FAT32 using this program on the computer first. (do not tick quick format)So I formatted my SD card in the camera and it set it to exFat, how can I easily reformat it back to Fat32 so I can run the firmware upgrade please.
Even though new firmware of late November and newer defaults to exFAT when placed in camera, hopefully future Firmware updates won't require re-formatting back to FAT32 again 🙁Before updating, please format the card to FAT32 using this program on the computer first. (do not tick quick format)
viofo.com
A229Pro/Plus: To update our newest firmware, you need to format your card to FAT32 first.
With the newest firmware, you need not to format it to FAT32 when you update the next firmware.
Because the exFAT file format has been added to this new firmware.
Is there a recommended program to format as FAT32 on macOS, and linux, given that the recommendation provided is for windows.Before updating, please format the card to FAT32 using this program on the computer first. (do not tick quick format)
Probably easier just to keep a smaller (32GB, they're cheap) card around for F/W updates.Even though new firmware of late November and newer defaults to exFAT when placed in camera, hopefully future Firmware updates won't require re-formatting back to FAT32 again 🙁
You don't need to place only one of the firmware updates on the memory card at a time. You can place both on the same memory card. If both are on the same memory card, the front camera firmware will be installed first. After the front firmware is installed and it reboots, it will boot up and after a few seconds it will detect the rear camera firmware file is still on the card. It will then start installing the rear camera firmware. I've used this approach numerous times and it works every time.That's basically what I have now done. I've got two cards, one with an F on the front, the other with an R. You can probably guess which firmware goes on which card 😀 Why two cards? I'm too lazy to go back inside and drop the other firmware onto the same card, and I don't have a laptop so cannot sit in the car and do it from there 😀
Vantrue do the OTA update thing very well at least on the android side of things. Can't speak for iOS cos don't have first hand experience there.Would be nice to have ota firmware updates and ditch these sdcard ones, would also be nice to access to beta ota firmware too.
