LateralNW
- Nov 7, 2016
- Australia
- VArious
In the case of an external waterproof rear camera, it may be possible to cover the areas that are blocked by the bed of a pickup truck. However, for a typical 2-channel dashcam setup, the rear camera is optically limited and will inevitably cover a viewing area similar to that of the S1 4K rear camera.
If the camera angle is tilted upward, more of the sky can be captured and the pickup truck bed may appear smaller relative to the overall frame. However, in that case, the areas on both sides of the bed will no longer be visible.
In practice, this would require using a rearview backup camera with a monitor together. However, I’m not yet certain whether using two separate rear cameras in this way is truly appropriate or practical.
An external rear camera for a dashcam is designed to remain powered on and record continuously in all driving conditions, whereas a rear backup camera for viewing purposes is activated only when the vehicle is in reverse, providing a visual aid through a monitor for parking safety.
Even if we were to develop such a product, it would need to integrate these two very different applications into a single external rear camera. As you can see, there are many factors that would need to be carefully considered.
While it might be easy to release a product simply to satisfy the idea of having a waterproof external rear camera, I believe that a manufacturer’s responsibility is to carefully evaluate efficiency and suitability and to develop a solution that can be used effectively by a wider range of customers.
Have a good day
Thank you for the reply I think the topic changed by a misunderstanding.
A reversing camera I agree is not what a dash cam is consider when making a purchase.
My idea was to just extend the normal dash cam to outside so it could be connected to the rear of the vehicle. That way the tray when loaded would not block the view of the rear camera.
I suggested waterproof because it would probably be mounted in the open air.
Cheers
