Changed to my class 10 samsung card I had in my phone and so far so good.... for the first That will be the best
Thanks for the help!
test that from post#441 without changing anything, downloading, extracting copying in root directory and restart.
#set 4GB file
writew 0xC03A8520 0x2004
It's a little higher than default 2mbps instead of 0.5/0.6 mbpsI installed the firmware but didnt have any problems with wifi preview its smooth as it was before. Am I just lucky or did you change the preview bitrates in firmware 🙂
...due to an idiot friend cutting the ribbon by mistake when trying to do the lens fix...
Very clever to give the cam to an idiot friend to do the lens fix...
You could use parts of this script here to enable wifi which gives you access again via your smartphone (where you can set the wifi to be on everytime you switch the cam on):
https://dashcamtalk.com/forum/threads/camera-wifi-in-client-mode-working-ash-script-inside.12239/
The following line should set it to the desired frame rate (plus high bit rate of 50Mbps)
writew 0xC05C1EE2 0x4248
About the time stamp I have no idea but if you really need that I'm sure you can do that afterwards with the vlc player.
normally it splits when having 2gb, 7 minutes for 2k recordings per file.Can anyone tell me why my videos seem to split i just went out in car for 10 min test but the video split into 2 different files but there was no interruption on recording ? Thanks
hi gente in your script "line 11" you forget a "w" anyway that line has # but if someone activate it it won't work.. 😉i use that one from post #4...test it
https://dashcamtalk.com/forum/threa...nhappy-advices-help-please.15733/#post-207328
if you're used with script, post your here and we will help you.. 🙂I also want a more cinematic look when recording.
A little bit like this
Which parameters do I have to change?
Thanks in advance guys. You are all really awesome. @Fried his fw really is stunning.
