Xiaomi Yi Custom firmware with lastest revision
normally it splits when having 2gb, 7 minutes for 2k recordings per file.
yep thats exactly what happen, so if i want longer video, i have to choose a lesser option? what is next best and the limit? thank you for the reply
you could try to add this line in a script and see if it split video properly to 4Gb instead of 2Gb..
Code:
#set 4GB file
writew 0xC03A8520 0x2004
Code:
#set 4GB file
perhaps a little beyond me, I managed to flash the firmware, but not sure about modifying or writing a script is it as simple as creating a plain text file, adding the lines and saving as the right name?
thanks
not exactly, take a look here, for more information about scripts if you want DIY.. 🙂
Hi !
Just testing the last firmware, it seems that my 1920x1080 60fps videos are not set to 35Mbps as the 50fps are. Can you confirm ?
Thx.
Hi @Fried
Here is my CINE script... based on fw 1.2.13 and @gente his script
I can't test it myself yet because I lended my Yi to my nephew...
so I would really like feedback of some testers
NR is set to 0 so I expect really bad footage at night so if someone wants to test it, daytime would be perfect
I think I set the colors a little too bright I don't know
Thanks again for helping me!
Hi !
Thx.
I'll check ..
Hi @Fried
cine effect I thought a very flat image in this script I see you have pushed hard vibrance/saturation, to have an idea how movie effect should be try nutsey Yimax script here... night footage will be bad most of times cause this cam isn't born for that.. if you feel color too bright try to replace these lines
Code:
#setting vibrance and saturation
t ia2 -adj ev 0 0 120 0 0 150 0
#set gamma level between 100-150
t ia2 -adj gamma 140
Code:
Thanks mate! You're right.
I've push too far those parameters.
I think that low gamma level, makes the video overall darker by making the colors less "powerful"
Am I correct?
I will use nutseys goprawn but maybe I
will set coring to 8 for disabling or 10 cuz
I really want pure focus.
ow yeah do you think script for helping lens set to focus will help? Because our cam has a wide angle lens so maybe zooming in by script is an option? Or should I just buy a lens kit?
Thanks again!
for setting lens ocus there's a specific manual procedure but you have to open it and rotate lens (after remove glue) with cam connected to a monitor via miniHDMI and focus an object @50-60cm distance...
Could you guys tell me if I put the camera into a lower res than 2k for video, will the video last longer? ie more than 7 mins?
is not a resolution problem but microsd write-speed issue.. anyway you could try script to cut video @4Gb instead 2Gb..
card should be fine, you could try a lower resolution, if you set a lower quality with custom firmware you'll lost 35Mbps cause I set it only on high quality..
imho there isn't a best firmware but a good balance quality/perfomance, in this thread you find that good balance at least for me...
aah some good script you mean, again there isn't a best one it depend what you like...
in this thread there are many scripts posted...
As I say go back couple of pages to find some scripts... 🙂
every file is 2GB for normal, lower resolution means less information and so 2GB of 1080p for example last longer than 7 minutes of 2K!
I mean about 9 minutes....
Hi !
Thx.
jeah for me too 1920 and 60 fps is around 25 Mbps. First shor 10 s video is 35 but then 2 Gb video is around 25 Mbps ! Long shots making a camera pretty hot !
what is good its looks like with fw camera starting litle bit faster then original fw
