Calder
- May 24, 2015
- United Kingdom
thanks, i just flash it and no problems.
Same here, thank you.
Hi all.
Find hereafter my fisrt custom firmware for Z221, based on 1.1.0 firmware.
Please note I haven't check it yet in my YI because I'm not at home: SO use it at your own risk.
I will edit this message after the test.
Edit: yes it's OK you can flash it. Thank you all for testing without fear ;-)
https://drive.google.com/file/d/0B8UK_zbAneq3bzJpc21mRXBWMkU/view?usp=sharing
Guys, just release a bit secret, the newest firmware already support bluetooth..
What's the quickest way to create a new firmware file from an older firmware i've already edited? I tried to take the prs.a7s and put it in the folder of the new one but it didn't work when updating the camera. It stayed on the old firmware
There are some bluetooth scripts present in 1.1.0 but there is still no device present in the system (HW 22l). Drivers? HW revision? I will know more when my cam(s) arrive.I'm quiet sure it's the Bluetooth pairing mode
je.... you are just a genius!!!!! now all you need is a bluetooth remote control..I've found something, if you tap quickly twice on the WiFi button, there is a beep, if the WiFi was off the LED switch on fix and goes off after 60sec. I'm quiet sure it's the Bluetooth pairing mode for the remote shutter. But i can't detect new Bluetooth device with my phone.
Hi all.
The same as it beforeHow many MBPS on 1.1.0 firmware?
it yourself. It's very simple and takes little timeCould somebody mod the firmware v1.1.0 Z22L to 30mbps please?
Honestly learn to do
Yeah, I would like to learn and make it but I don't know how can I do it.
