Hi Funnel,
The 2880x1620 resolution script seems not working perfectly, sometimes my camera cannot stop recording (maybe it has crashed).
Hi Funnel,
Hi Funnel,
Seems like it's just an upscale. No new details in the picture plus blurry edges after bilinear (?) transform.someone up to the task of shooting some fine lines in 2304 and 2880
over at https://github.com/kerenmac/Xiaomi-Yi/blob/master/Autoexec_commands.txtt cal -raw [mode] [count] [compress]: raw caputre
mode = [0..8], 0:VIDEO
2:LOW-ISO STILL
3:HIGH-ISO STILL
4:MID-ISO STILL
5:LOW-ISO MULTI-CAP STILL
6:HIGH-ISO MULTI-CAP STILL
7:MID-ISO MULTI-CAP STILL
8:MULTI-FRAME HIGH-ISO CAPTURE (old pipe only)
9:VIDEO HDR(dump Raw, idsp config only)
count = number of pictures to capture
compress = [0, 1] optional, capture and dump the compressed raw
t cal -rawext [mode][frame][mainwin_w][mainwin_h]: raw caputre
mode = [0..3], 0:VIDEO, 1:FAST STILL 2:LOW-ISO STILL 3:HIGH-ISO STILL
frame = number of frame to capture
mainwin_w = main window width
mainwin_h = main window height
t cal -rawenc [filepath] : raw encode flow
filepath = file path for configuration file
Yes, you can capture RAW stills with that command.I found this excerpt:
does this part have any merit on capturing raw stills or video?
there is a mode switch with the RAW, that can be set to "video". - you think that doesnt work?
These are supported by Ambarella chip, but camera sensor can't output them. Though I'm not sure what sensor WDR really isDid you ever try the WideHD or the HDR 1080p modes?
Autoexec scripts for firmware version 1.1.0
Bitrate table start: 0xC05C380C
Video resolution NTSC table start: 0xC05C464C
Video resolution PAL table start: 0xC05C4AC0
#set video resolution to 1600x1200 60fps
writeb 0xC0697626 0x0C
#set bitrate to 30Mb/s
writew 0xC05C3A52 0x41F0
#set video mode 1600x1200
writeb 0xC0697626 0x0D
#set bitrate 30Mbps
writew 0xC05C???? 0x41F0
now under firmware 1
