nutsey
Is that for better handfling flickering from both 50 and 60 Hz power sources?For example, from 30fps to 27.5fps etc.
I found how to enable WDR by v_max from 4pda
What you need
- FW 1.0.7CN
- FW 1.0.7NA
- Multipatch V5
1. Copy paramdef and media_app_zip.bin from Multipatch V5 to both Chinese and English FW
2. Install Chinese FW to your Dashcam
3. Resetting Dashcam to factory default and enable WDR in Advance Settings , you can use phone to google translate or this Link to navigate, don't forget to disable parking mode before turn off Dashcam in case you inadvertently turn it on
4. Install English FW with paramdef and media_app_zip.bin from Multipatch V5 DO NOT reset after this
After turning WDR on I found videos have increased in details and noise, Thanks again for your hard work nutsey.
Translated UI text of Chinese 1.0.7 fw to English and added the V5 patch to it. There are some limitations for text strings length, but I suppose it's not a big deal for anyone.
Hi,Hello nutsey,
Tell me, this version have the time lapse correct ?
How about the voice language ?,, still in Chinese ?
Can you upload it to mega or other place with the V5 patch as option ?
Was your device battery fully charged?I downloaded and wanted to update and now I have a brick, I did everything like every time the format, update, I turned the right button on the webcam and the large camera blinked and turned on but does not respond to any button can not be turned off.
Happened to me a few times. It's probably because of the low battery on the device. Just hold for 30s-1m the power (long) button and it will turn off.I downloaded and wanted to update and now I have a brick, I did everything like every time the format, update, I turned the right button on the webcam and the large camera blinked and turned on but does not respond to any button can not be turned off.
See my post above. If it doesn't start after shutting down, connect it to power and it will automatically start.I managed to restore I discharged the batteries to zero and after recharging came to life I downloaded this Chinese software but I can not find 50/60 Hz I do not have in the application,
nutsey how would you write a table what settings to use?
Yes, it is. The bitrate value raises up to 35 Mbit/s if needed to preserve fine details and to avoid compression artifacts.Is this normal ?
Ah i see,Yes, it is. The bitrate value raises up to 35 Mbit/s if needed to preserve fine details and to avoid compression artifacts.
make sure the camera lense is clean also the car window glass. maybe you touched the camera lens with your fingers when you updatedI've just upgraded directly from Chinese stock 1.0.4 firmware to Custom 1.0.7v5 (2019-12-19) firmware.
Did full factory reset. HDR On.
The image quality are not as good as before. See my screenshots attached (notice how sharp the tree leaves are in stock firmware).
Another question: is it possible to make the camera connect to existing WiFi network in my car rather than starting its own WiFi?
I didn't remove the camera from mounting position during update, it's unlikely the lense is being touched.
I have a sophisticated 4G+WiFi with Raspberry Pi network in my car.
I'd like to write scripts/code to pull the videos from 70mai and upload it to cloud storage & broadcase a live stream of the RTSP feed as well. Hardcore stuffs. 🙂
Alternatively I have to plug another WiFi dongle to my RPi and connect to both networks at the same time. Do-able, but not the cleanest solution.
Compare license plates. not leaves. Use same shooting conditions and settings.how sharp the tree leaves are in stock firmware
