may be you're right.
now imagine that who ever makes the chipset (let say Novatek) desided to slightly reduce the potential of the chipset to the public, and the chipset can actually record the video 1296P@45fps. is that not possible?![]()
It is limited by chipset.I already wrote that anything over actual values are not supported by the chipset.
60FPS is possible under 1080p. 60FPS is not possible for 2K.
45FPS is useless for 1080p if we already have 60FPS. I remember Mini 0805 added for the first time the 45FPS option and is used by almost nobody. For a dashcam is more imporant a higher resolution compared to FPS.
enjoy,
Mtz
so before a firmware v.2 install you would probably say that "the higher bitrate is not supported by a chipset", right?I can confirm the change regarding 1440p being recorded at 24mbps. I checked the video properties and I can also see that the 10 minute loop file size is now 1.68GB, compared to the previous 1.02GB at the lower bitrate.
technically possible, they don't though
people say what they say not because it's true but because they have a reason to say so.
is it possible that the current chipset works @ 80% or even less of its maximum power? and the limitations on a chipset set to satisfy most of the buyers for at least of a year or more due to possible overheat etc?It is limited by chipset.
I wonder if they have individually controllable LEDs under the buttons... if so, then maybe they could use the one under the mic button to indicate mic mute.@viofo - Ver. 2.0 downloaded today has a power off bug. If you manually power off the camera, while power is still being supplied to the camera, the camera will turn on automatically after about 12 seconds and start recording video.
Things I'd like to see in next version:
1 - Power off warning sound (very important)
2 - Prior and current file lock after g-sensor is triggered (very important)
3 - Menu option to change recording light from solid to flashing when recording
4 - More visible change when audio recording is muted (small slash mark is hard to see)
My camera does not have this problem. Powered it directly from camera, from GPS mount, with or without GPS mount I don't have this problem.@viofo - Ver. 2.0 downloaded today has a power off bug. If you manually power off the camera, while power is still being supplied to the camera, the camera will turn on automatically after about 12 seconds and start recording video.
@viofo
I just tested this with my camera as well and it did not turn back on. I haven't had the format warning either. Did you default your settings after the update?@viofo - Ver. 2.0 downloaded today has a power off bug. If you manually power off the camera, while power is still being supplied to the camera, the camera will turn on automatically after about 12 seconds and start recording video. The camera has also twice displayed the format warning when it powered up automatically despite the card having been formatted minutes earlier.
I formated, used loader, and reset all to defaults. I will download firmware again and reinstall just in case there was some glitch when I updated the firmware on my camera.
