- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
if you have a card reader that's a better option anyway
Okay, with the SD card in the card reader, and formatted, I drug the new file to the SD card and double clicked on it and it's trying to open with VLC program, and displaying an error.
A119 V3.1B firmware does not automatically reset the date/time if the GPS setting is "OFF". If GPS setting is "ON", the date and time are automatically reset, regardless of the GPS Info Stamp setting. Neither of these menu settings changed with the V3.1B beta firmware. Since I don't have software to dig out the embedded GPS data, I did not test to see when the embedded data is turned off, but I would speculate that it is switched off when the GPS setting is set to "OFF".Looking forward to it, though I'm hoping it the GPS will still set the time automatically - that is the main reason I have the GPS model.
Try this:FWA119S.bin File downloaded to computer, transferred to sd card, put sd card into camera, plugged usb into dashcam and computer, camera simply turned on and started recording. I guess I'm stuck with no update.
Интересно есть ли способ вернуть к жизни 119S, если прошивка не удалась.
Например инжинерный файл, или другой способ реанимации.
Вобщем как поднять 119S из состояния "кирпич"?
Для Ambarella есть программа DirectUSB и инжинерный файл elf.
Для Novatec есть , что то подобное или только через программатор.?
Значит для 119S , загрузчик вшит в каждом ПО ? или есть отдельный файл как для 119?
LDBA 119 bin, есть такой для 119S ?
