vvs49
- Jan 8, 2015
- Ukraine
That would be the case for everyone.He claimed that he noticed it after update to v1.7
Well, since it's blurry even after reverting back to an older firmware, it's most likely HW issue so you should RMA the unit.I just rolled back to v1.6.... same sh*t, different day.
I'm not sure now when exactly HDR got implemented for A139 but that could be the cause of the double image (it takes two images with different exposure), that's why HDR timer is present since one of the latest v1.7, to address the concerns and to let one decide when HDR is needed.But why are there two frames overlapping all the time?
This is how HDR works in low light.But why are there two frames overlapping all the time?
I always disabled HDR/WDR under v1.6 and right now its also disabled. I reset the camera twice (by app and by reset-button), reconfigured it and tested it out of the car.This is how HDR works in low light.
I wish the source code was public so we could improve the software ourselves.V1.7_20220722
I don't like it, I will modify it!!
V1.7_20220722
This type of thing makes me stick with firmware if it is working ok.I had firmware 1.7 in the spring of 2022. Viofo notoriously turned itself off. Once someone dented the door in my factory new car at the hipermarket's parking but nothing was recorded.
When I reverted to v1.6 everything was back to normal that is now it always record.
Stick with low bitrate mode with G-sensor at the maximum level and you won't have such an issue.I had firmware 1.7 in the spring of 2022. Viofo notoriously turned itself off. Once someone dented the door in my factory new car at the hipermarket's parking but nothing was recorded.
viofo.com
Has anyone tried this new version yet?New firmware released
V1.7_20221215
manual
VIOFO specializes in professional-grade dash cameras featuring Sony STARVIS 2 IMX sensors, 4K ultra-high-definition recording, and advanced multi-channel systems from 1CH to 4CH. Known for superior license plate capture — including dedicated telephoto dash cams for long-range identification.viofo.com
Yes, I did. At spring '22. Be careful because my Viofo very often turned off or restarted by this version of firmware. Once on the parking place my fresh car was hit and Viofo did'nt registered this event 🙂Has anyone tried this new version yet?
This isn’t the same version 1.7 you reported running in May, this was released in DecemberYes, I did. At spring '22. Be careful because my Viofo very often turned off or restarted by this version of firmware. Once on the parking place my fresh car was hit and Viofo did'nt registered this event 🙂
A139 F R - cameras Firmware V1.7_20221215 HDR enabled!!Has anyone tried this new version yet?
I supposed such a possibility. That's why I wrote "be careful" and not "don't use".This isn’t the same version 1.7 you reported running in May, this was released in December
