camera switches after some time from 1440p/30fps to 1440p/60fps
Btw: That's v20210324 from the previous page.V1.1
VIOFO A139 Dash Camera Firmware
Please click below for the A139 support page. A139 Support pagesupport.viofo.com
2017 Prius C with 2x12s DVC about 700 watts @1Ohm.Yes we dont want any G-sensor on while driving.
Dont got any bass in my car, but once in the good old days π lets just say i am glad i am not hearing impaired today. 3 X 12 " 500 watts each, that rocked a little 3 door euro hatchback.
So I hit up Viofo on Facebook messenger about this, and they said would pass it onto their company. Then said "We will provide you a special firmware later."Yes we dont want any G-sensor on while driving.
Thatβs interesting then although itβs of little use being locked in parking mode if it then fails to unlock when back in driving mode.@SawMaster @Mtrev So, according to Viofo's Facebook the button-lock in parking mode is indeed by design. To be honest, i don't like it (either in parking or normal mode). In case of an accident, cars can shut ACC off and won't turn on, then one isn't able to enable Wifi as the only access to footage at that moment. Or while parked, one is not able to flag an event in case of a light scratch (which probably won't be recognized by a G-sensor). Et cetera.
I can see the usecase, as @SawMaster mentioned before, when a car goes into unknown hands, to minimize an interference with camera, but when it's in owners hands...
Or maybe make it a little less sensitive, I am still getting g-sensor events when I stop accelerating, if the engine is near maximum output at the time.Just purchased the A139 and got newest FW 1.1 updated. Can we please add the option to turning off the G-sensor during regular use?
I have a car stereo system that has alot of bass and A139 keeps detecting incidents during deep bass hits.
I rather manually lock videos when driving.
What do you have the G sensor set to? Mine is set to low and I've only had events store when I've caught pot holes. sharp acceleration and braking or even fast cornering don't trigger them on mine.Or maybe make it a little less sensitive, I am still getting g-sensor events when I stop accelerating, if the engine is near maximum output at the time.
Either default or low, not sure which at the moment. It is not sharp acceleration that does it, normally it only happens when I pull out of a junction in 2nd gear and accelerate up to the 60mph speed limit before changing gear, it triggers either just before, or on the gear change.What do you have the G sensor set to? Mine is set to low and I've only had events store when I've caught pot holes. sharp acceleration and braking or even fast cornering don't trigger them on mine.
I had it set to lowest sensitivity. Viofo made me a custom FW which removed the. G-sensor and said they would include the option in future FW update.Or maybe make it a little less sensitive, I am still getting g-sensor events when I stop accelerating, if the engine is near maximum output at the time.
Interesting seeing it in that video, the exhaust sounds quite loud could it be from that or something resonating? Iβll have a go pulling away and accelerating in mine a bit to see if any trigger.Either default or low, not sure which at the moment. It is not sharp acceleration that does it, normally it only happens when I pull out of a junction in 2nd gear and accelerate up to the 60mph speed limit before changing gear, it triggers either just before, or on the gear change.
Also triggers when crossing cattle grids, which most cameras don't, only A139 and B1W do regularly.
I think this was on default, but with an old firmware, and a 50mph speed limit (GPS is a little slow to catch up):
