Karagandinez
- Nov 27, 2020
- Deutschland
- Germany
- At the moment Viofo, Vueroid and Vantrue
Has anyone tested the heat output of the A229 Plus/Pro?
While the A229 Pro has heatsink (And the Plus does not), it records at a higher res (4K) which results in higher bitrate which equals to more heat.
I don't mind spending the $$$ for the Pro, however I need something that will survive heat better (As much as 40C in summer) and the one that heat less while in use (I will use my camera for front and rear only).
Any ideas?
VIOFO A229 Pro - Testing / Review - RCG
On Tuesday 26-Sep-2023, I was given permission from VIOFO to start posting info about the A229 Pro / A229 Plus dash cameras. I have not started my testing of the A229 Plus dash camera yet since it is scheduled to arrive later today. A229 Pro Unboxing The VIOFO A229 Pro will be sold in two...
A229 Pro Test & Review PP
Indeed. Of course cooling the walls of a room / box ( assuming they are not insulated ) will also make it colder inside the room / box, but the candle in the middle of the room will still burn just as hot. I think it is better to focus on M2 storage for dashcams, and you can get those with a...
