country_hick
- Dec 10, 2014
After receiving a new dash cam its quality is always questionable. It could fail very quickly or last a very long time. Even a trusted name can have a defective part installed.
To check out the quality of your dash cam and sd card here is what I think makes sense. (Battery equipped dash cams could destroy a battery this way.)
Stress test the dash cam. To do this beg, borrow, or buy a house voltage to USB power adapter with the proper wattage available. You could use your computer with the dash cam attached as an alternative. Some computers have USB ports that always give power, some do not.
Attach your new dash cam to your USB power. Leave the new dash cam running in your house or office when you are not in your car. You will be recording the most disappointing footage in history but there is a reason to do this. In theory in 1 week you could put 168 hours (in reality it would be less) on your dash cam. In 3 weeks you could have 504 hours on your equipment. After 28 days you could have 672 hours on your dash cam.
Remove the sd card and check to see if it is recording correctly every day.
If everything lives at this point it can be considered a solid piece of technology that can be trusted. If instead the dash cam or sd card fails it all happens within the 30 day window all sellers allow.
I suspect that removing the battery from a battery equipped dash cam could allow the same tests to be done. Those who know more than I could disagree with this idea. I only know that charging and running can ruin some of the batteries dash cams use.
