In this post I will attempt to measure how much power / capacity / runtime is left in the PC8 when using the
@viofo Hardwire Kit set at the lowest cut-off voltage of 11.8V.
The hardwire kit is designed to provide reliable parking mode functionality for Viofo Dash Cams, and also serve as vehicle starter battery protection with preset voltage values of 12.4V / 12.2V / 12.0V / 11.8V.
This little device is an engineering marvel.
However, when used with a dedicated dash cam battery pack the lowest cut-off value of 11.8 Volts prevents the full capacity of the battery pack from being used.
The PC8 internal BMS (battery management system) continues to deliver power down to 11.0 Volts.
I will attempt to measure how much power / capacity / runtime is unutilized, (as the battery pack continues to deliver power from 11.8V down to 11.0V).
This is like have a car with a 20 Gallon fuel tank, but only 15 Gallons can be used.
First I measured the power consumption of the A119 Mini 2 in Low Bitrate Parking Mode with official public firmware “0605” using my Fluke 115 multimeter.
171mA @ 12.60 Volts = 2.1546 Watts
I started with a fully charged PC8 at 100%.
I connected the Viofo Hardwire Kit set at 11.8 Volts, and my DROK load tester.
I set the DROK to draw 2 Amps @ 5 Volts = 10 Watts.
The Cellink Neo App indicated the estimated run time in this configuration was 7 Hours 18 Minutes
After 7 Hours 6 Minutes the Hardwire Kit shut off power to the DROK load tester.
I disconnected the hardwire kit & DROK from the PC8.
I connected the CLA Output Cable to the PC8, and connected the included Viofo dual USB charger for the A119 Mini 2, and my KEWEISI USB power tester.
I connected the A119 Mini 2 with Low Bitrate parking mode enabled.
After 5 minutes on “inactivity” the Mini 2 went into parking mode.
The Mini 2 continued to operate in parking mode for 1 Hour 51 Minutes.
The KEWEISI USB power tester indicated 3.95Wh was drawn from the PC8.
The PC8 has a capacity of 96Wh.
This means under these test conditions the Viofo Hardwire Kit set at 11.8 Volts only allows approximately 92Wh of the available 96Wh, and 4Wh is left unused.
Based on these test results it would be nice if Viofo could add a selection to the hardwire kit to completely disable the low voltage cut-off for use with dedicated dash cam battery packs to increase parking mode duration.
