rcg530
- Jan 23, 2021
- California
- 70mai, BlackVue, Thinkware, Vantrue, Vueroid, VIOFO
I've been waiting for a firmware update beyond 1.002 since Pittasoft stated some of my power consumption testing issues with power saving mode parking mode might be addressed with a later firmware [1.003]. I haven't received an updated firmware yet [sent an email asking about that].
This morning, I decided to install the Elite 9 in the that currently has the DR970X-2CH Plus dash camera. I don't have enough windshield space to accommodate a seventh dash camera, so I removed the DR970X-2CH Plus dash camera and installed the Elite 9 front/rear cameras in their place.
That car currently has a CM100LTE module, not the later CM100GLTE module. I decided to try what some people upgrading their system might try to do. I left the CM100LTE module in that car instead of installing the CM100GLTE module I was using to test the Elite 9 in my office. I was able to successfully register the Elite 9 with the BlackVue Cloud service using the older CM100LTE module. I'll see if using the CM100LTE module causes any problems.
I also decided to take the path of least resistance when it came to the installation of the Elite 9 rear camera. I reused the coaxial cable from the DR970X Plus dash camera. Pittasoft suggests that you use the cable provided with the Elite 9 [has a "6" on front camera connector], but they did state that if you want to reuse the older cable "it should/might work". I'll see if using the older coaxial cable is a problem for the new 2K rear camera. I can imagine that if you install an Elite 10 with a 4K rear camera, reusing the older coaxial cable would not work well.
