Do you want the camera to turn on and off with the car? If you do, then you don't need a voltage cut-off. Just wire the kit into an accessory fuse (shuts off with the ignition).
No, I want to take advantage of the parking mode. estore009 recommended this kit:
https://www.ebay.com/itm/131229994547
I wouldn't get that one if you want to use parking mode. The voltage cut-off on these basic kits are usually too low <12V.No, I want to take advantage of the parking mode. estore009 recommended this kit:
If the parking mode is continually running, I'll probably go with a power magic pro
Yes, this is what I thought, but the control box output of the Power Magic Pro is between 12 and 24v therefore the female cigarette socket must have a voltage reducer from 12/24v to 5v - but the male cigarette plug adapter that comes with the B1W camera also has a voltage reducer to 5v.USB powered cameras are 5V
Hello, I'm thinking about buying this camera. Can someone please clarify this:
Is the bracket/pad that is glued to the windshield removable from the rest of the camera?
I don't want to leave the camera mounted when parked, tempting scum to break into my car.
