Deleted member 46308
- Feb 19, 2018
Kudos to @estore009 for prompt and courteous service.
I have exactly the same issue. After trying to upgrade the firmware the green LED is now ON but there is no audio message and no wireless connection. Please help.
We can reset the camera by loading firmware with a Windows laptop!Ditto, exact same issue. Please PM me the fix, or post it here. Thanks. @estore009
Please download this tool here (Only works with Windows system)
https://drive.google.com/open?id=1WcMO4W664dvM--CxoY0QMjMfmph3pBcG
Also, please load this BIN file from this link (V1.06.20180528s standard firmware)
https://drive.google.com/file/d/1SY9W1kx7jMn7pFl1MZGEfpVfz-a32Mlh/view
And then you can load it in this way: No need insert a memory card into camera unit, please note!
1) Keep pressing this button when plugging into the laptop USB socket.
2)Open this tool and select this "load bin file" section and load this bin file which lists in the second link.
3)Click this "start update"
Help me to boost our camera around your friends if you like it!Awesome! Worked like a charm. Thanks for the prompt reply and easy fix. Big ups to @estore009.
I am sure this tool can work with Windows 10, just one tip for you:I have brick and I am trying to reset it according #44.
When I plug it into laptop I get message kind of "device not recognized".
Can you help to look for drivers for Windows 10 ?
Thanks a lotYou've already done disabling driver digital verification? How to do this you can see here: https://videoregforum.ru/threads/so...cepty-po-vosstanovleniju-dlja-ambarella.1871/
There is also a B1W topic on the Russian forum https://4pda.ru/forum/index.php?showtopic=882838
See this post #43 https://dashcamtalk.com/forum/threads/bricked-b1w.34658/post-458536hi i have the same problem the camera stays green i cannot do anything how can i fix it
[/QUOTE
Do you have instruction please beacuse when i connect my dashcam to my pc it wont load ?
And wich files do i need step by step?
Thank you my dashcam is back to normal1) Keep pressing this button when plugging into the computer/laptop USB socket.
2)Open this tool "exe" file and select this "load bin file" section and load this bin file which lists in the second link.
How about its voice prompts and WiFi SSID?Hi, after following these steps, the dashcam is still stuck at the green light and won't record after turning on. Can you help? Thanks.
Do not plug the dashcam into your computer USB socket for power source! Just use your phone USB wall charger to power on it, then it will work!The only voice prompt is "SD card detected". I am able to see the WiFi network of the dashcam but unable to connect to it.
R | cam bricked? | B1W | 10 | |
Z | B1W bricked after updating firmware. How to fix ? | B1W | 9 | |
N | B1W bricked | B1W | 2 | |
S | I messed up, I bricked my camera. | B1W | 9 |
