Also the new CFW v1.1 works absolutely perfect.
This time I installed it by first formatting the SD card with SD formatter, then made it fat32 with 32kb clusters, the old schol way with guiformat, and then re-installed 2.0 Stock, wich went trough with no problems. Then the procedure I already described in a previous post, the CFW update
No problems here. The new Version now also seem to have the bad pixel correction fix, which 1.0 did not seem to have...
@ptrout
Make sure you format propperly. I also ran into problems with the cam, not beeing completely initialized.
The Problem was either that I just deleted the files, or let blackvue software delete it, or the fact that I tried several times... just do the procedure again, maybe with another SD-Card- For tests it can be a smaller one...
(an indication that something was wrong with the config file was, that the iphone app crashed when saving, or took very long to save the modifications....)
