I finally had chance to drive at night after firmware update and from what I remember, it's much darker now.
Video is even darker than Z7 at night.
I remember G90 was much brighter than G1WH before and Z7 was similar to G1WH.
Now Z7 video is brighter at night. G90 lost all the details at dark areas, it's even worse than G1WH now.
Not good.
I'll have to go back to r328 and see if that's the case but I'm pretty sure it's the firmware as I remember G90 was much more brighter at night when I compared against G1WH and Z7 is just same as G1WH.
Screenshots:
G90 with 18mbps firmware: Dark areas are completely black with no details.
Garage door on the right is not even there.
Z7: Much brighter, more details in the dark areas.
Where are the houses?
Z7 screenshot has the houses on both sides.
Almost ran over a rabbit today.
Houses are seen on both sides.
I know Z7 can't be better than G90 but this firmware did something.
Now G90 works good at good light but suffers badly at low light.
However, when there is enough light, G90 is better than Z7.
That should be the case at all light levels.
G90 with street lights: More clean/clear.
Z7: not clean.
But when light is
very low, G90 becomes really dark:
G90:
No trees on the left at all...
pitch black.
Z7:
CAn see trees lining up in the left median.
G90: Right side is so dark, you can hardly make out there is a house there.
Pitch black on the left side, no curb is visible.
Z7: Very easy to see house. Left side curb is also visible.
