nutsey
Yeah. Working OIS and HDR do their stuff.I had a nexus 5, I took pretty good pictures with it.
App still crashes as soon as it should show the live stream from cam, and image is swapped left-right. I still think that the sensor is OV4689 and not IMX179
The app crashes for me as well, I found one that works though. Its name is SportCAM, the icon is similar to XDV.
The app is pretty much the same, probably a tad less buggy.You can take a rootfs from another image if your script + kernel is ok. As long as it contains the imx179 module you can run it just fine. Then the XDV app will run. Is the sportcam app better than XDV (besides not crashing)... xdv is very buggy. It fcked up the OS on one of my phones and now I get an FC when wifi connects.... I can fix that a million ways probably but the ****ty app is ****ty.
where is script.bin location I copy thereYou have crane4k30imx179s_sdv-eng 4.2.2 JDQ3
Wooo, different module version !
You only have different LCD than me, you should be able to use my image no problem if you paste in your own script.bin or just move rootfs.
your real camera name is:
key_camera_exif_make = Qlippie
key_camera_exif_model = Q1
but I power off and power on the cam with battery OK button don't work.
I don't know how to thank you, works perfecly, even better than before due to the newer firmware.
I have to thank also nutsey for the backup script, and lapy for his backup, which was the right one. Thank you all, also for the informations shared. I hope to give back in the future, if I will have the possibility.
