Najeem
- Nov 26, 2014
Mine uses its internal battery, seems to last several days, maybe longer but I'd have to stop using it to find out!
The version that uses the Parking Guard mount will have to use the car battery since it is continuously recording video when parked, although with a slow frame rate unless its G-Sensor detects a shock in which case it switches to normal frame rate. Mine doesn't do the slow frame rate, just watches the G-Sensor and starts recording if it detects a shock - doesn't need the parking guard mount for that.
I don't know if both those modes of operation will be available on the released version, or maybe on the second release?
I assume the parking guard mount will be available with the first production units since it is described in the manual but I don't know, don't think Rayman is around for the next few days so you may have to wait for a proper answer. It is an option so I assume your order will not include it unless it was specifically listed as included.
Thank you for clarifying.
