U wanted a easy detach mount, so i put some magnets on the mobius camera, and then took a piece of steel and folded it over so it could slide in over the headliner.
And presto i had a quick detach camera.
Have you confirmed whether you have airbags over that fixed rear side window?Hmm noticed TonyM was using b1w for a while this might be a neater option for me (mounted on the window)
Would it solve the airbag problem? (I assume the airbag drops down where the plastic and headliner meet)
I have a top ridge on the plastic surrounding my windows but it has a cover running along it.
View attachment 48966View attachment 48967
I started with a pair of B1W. Then moved on to the A129 for better image quality, and low light performance. I'm hoping to fit the new 185deg lens into my side-facing A129 tonight, after some DIY to operate on the lens housing.Hmm.. More musings - My brother has a unused b1w, maybe I should borrow that and do a test with the fov
I'm fairly sure I don't have them on mine (an estate) since they would only protect the contents of the boot!
Indeed ( curtain airbags )
But don't worry me as mine was over the rear doors, and i have people on the back seat about 2 hours every year.
My new side cameras ( the K2S dual remote system ) are mounted on the fixed glass on the most rear part of the rear doors, unsure if airbag are all the way back there, if it is tough luck that's my new spot for side cameras.
On days when the car is covered in frost or dew, I get into the habit of clearing my side windows before setting off so the cameras have a clear view. I've not tried a rain repellent yet, but it sounds like a good idea.I have also got some "AngelWax H2GO" to apply to the side windows. Apparently it is quite a good rain repellent and should help keep the side windows clear when it rains. If it's really cold and the windows ice up or end up with snow I don't think anything can be done but the rain repellent might help a bit.
If left all day in parking mode, dashcams sometimes generate just enough heat to keep the screen clear in the region of the camera!Oh yes I always do this, I was thinking more of when it's been parked all day in parking mode, the other evening the windscreen was fogged up, as the weather gets colder I'll probably end up coming back to the car with a layer of snow or frost
